Problem with annotation tags when roatating scope box
6 ANTWORTEN 6
Nachricht 1 von 7
2033 Aufrufe, 6 Antworten
My problem looks like that.
I have a main view of a whole building with dimensions, spot elevation tags and so on.
Parts of the building are at different angles so to make them straight on the sheet I copy my main view as dependent few times, and apply scope box to each. Then rotate each scope box.
While dimensions or door tags that follow in orientation hosts, rotate ok, there are some elements that don't.
- text element of spot elevation tags. Graphic part is correct.
- curtain panel tags, with applied angle parameter
- stairs tags that are rotated inside a family
Is there any solution for this ?
6 ANTWORTEN 6
Nachricht 2 von 7
cbcarch
als Antwort auf: Anonymous
Two thoughts:
-Maybe use Duplicate with Detailing the views, instead of making Dependent Views.
-Try rotating the views, instead us using a scope box and rotating it.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 7
als Antwort auf: cbcarch
Unfortunately,
According to your first solution, we want to have one full view to keep consistency across parts so dependent views are must have. Rotating the view results the same problems.
Any other ideas?
Nachricht 4 von 7
Annotate after you rotated the scope boxes / views, not before.
Nachricht 5 von 7
Hi, I know this question was asked some time ago. But I have come across the same problem. I'm using a scope box for my project.
Did you find a solution?
Nachricht 6 von 7
russell.corder
Untitled Error.jpgI've got same problem but the above isn't much help; any other solutions available? My spot elevations and dimensions are
Nachricht 7 von 7
AINSAnne
Hi, same problems here.
Main view ->structural plan view which we show whole building and do modeling in.
Then we have these duplicate as a dependent views that have been done with scobe box.
And as you can see here, we need to rotate part 2, so it fits to paper size and looks fine.
This far everything goes like planned.
Tags and texts show in the main view and in the part 1 view ok because we don't need to rotate these views.
Part 2 we have problems because tags rotate automatically and of course in the wrong way. (or different way than in the main plan)
(I think these turn in to readable, and it doesn't matter is there dot in keep readable or not in the tags parameter)
We should have element ID:s showing same way in every plan
(f.e. hollow core slabs and deltabeams).  Could somebody help me.
