Strange roof cutoff
7 REPLIES 7
Message 1 of 8
apdim
435 Views, 7 Replies
Strange roof cutoff
apdim
Hey,
I created a roof and then added a cut-off level. The roof has different slopes on both sides. I'm getting strange form at the end. Any ideas how to fix it?
Thanks!
Strange roof cutoff
Hey,
Thanks!
7 REPLIES 7
Message 2 of 8
ralphdenhaan
in reply to: apdim
ralphdenhaan
You can try to use Slope arrows and see if this works for you? But then you will see a litle difference at the base of the roof.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 3 of 8
apdim
in reply to: ralphdenhaan
apdim
@ralphdenhaan It is same
Message 4 of 8
Simon_Weel
in reply to: apdim
Simon_Weel
The only solution I can see is to draw the opening of the roof; without specifying a cutoff level:
Message 5 of 8
apdim
in reply to: apdim
apdim
@Simon_Weel Thank you, it worked!
Message 6 of 8
constantin.stroescu
in reply to: apdim
constantin.stroescu
The problem is that you have different Slopes and thus when cut with vertical or horizontal planes the section thicknes will be different ( the perpendicular on face is equal)
  1. When using CutOff Level - Cut  with offset - the alignment is made to the bottom of the roof Face
  2. When using a Vertical Opening the alignement is made on the top of the roof
  3. You can Cut the roof with a Void Model in Place Family to obtain a horizontal cut and then build on the top of the cut
1
2.
3.
Constantin Stroescu
1
2.
3.
Constantin Stroescu
Message 7 of 8
in reply to: apdim
You can model a flat roof and edit sub elements, or a roof by mass faces.
Message 8 of 8
apdim
in reply to: apdim
apdim
I forgot that I have to reinforce it later, so I'm going to model it as the floor. Thanks for the replies!
