Noticed when using repeating detail component in Revit 2024, it is invisible while placing. it's not until I have finished placing that it becomes visible. also goes back to invisible when I select it. I have never had an issues with previous versions.
Gelöst! Gehe zur Lösung
Gelöst von ty_po. Gehe zur Lösung
Same here.
Changing graphics options, theme, view visual styles, view detail level, etc. all make no difference.
-G
I'm going to say its a bug/glitch as with every new release of revit there tends to be something not working properly until they fix it
It is and now being investigated. Invisible Repeating Detail Component in Revit 2024 and Revit LT 2024 (autodesk.com)
incase it helps anyone, i have the same problem as described above. but with the additional issue repeating detail components are not printing.
In the print settings, 'Hidden Line Views' Remove Lines Using: Vector/Raster processing. our standard is to use raster processing. however swapping to vector processing, the repeating detail items then get printed. i will have to do some additional testing to see what effects it has on the rest of our documentation.
I reported the issue to Autodesk in April 2023 and it was resolved in update 2024.1 Thank you.
