Stop section and detail tags from automatically placing in views
ccabralS4X5J
ccabralS4X5J
Hello, I am wondering if there is a way to stop detail tags from automatically populating in views after a detail is created. I wouldn't mind using the "reference another view" option only, I just want to be in control of which views my detail tags show up in. An example of my issue is when I create a detail call-out in a building section view, it will automatically make a detail tag that overlays the building section tag in the floor plans, elevations, and section views (please see screenshots) - It happens in any view that has section tags visible. I have been trying to stay on top of this by manually hiding the unwanted detail tags in every view, but I keep managing to print sheets that have detail tags on top of my section tags.  I have looked around the internet and can't find a way to stop it from automatically happening. I appreciate feedback on how others are avoiding this.
Thank you,
Christiana
RobDraw
Create different types and use filters.
Rob
Mirko.Jurcevic
Are you using View > Callout tool?
If yes, when you click on an instance of a callout in section, there is instance parameter called "Show in" and there you can select "Parent View Only". That way it will only show in the section to which it belongs to.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Yien_Chao
when you use detail View, you have the option of show in : parent vie2020-06-01_15-04-02.jpgw only.
Jeremy.Van.Ryswyk
What about in R23?
