Stop railing starting baluster from starting before the railing line
hugo_mpt_almeida
hugo_mpt_almeida
Hey! I made a railing that has corner balusters, however the starting one starts before the actual railing line. I tried changing it to justify at the beginning, center, end, spread; extende or decrease the line; but the result is always the same. The line is 10.000mm, and each baluster is 400mm, which divided results exactly in 25.
hugo_mpt_almeida
I forgot, but here are the baluster settings:
Change the Offset from Path under Railing Instance Properties.
hugo_mpt_almeida
That just makes the whole railing move backwards, it's the wrong axis.
hugo_mpt_almeida
Anyone? 🙁
Line 2=200
Line 4, Pattern End=200
handjonathan
Hi @hugo_mpt_almeida
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
