A serious error has occured. The current action has been cancelled.
5 REPLIES 5
DarrenLowe5325
257 Views, 5 Replies
Revit 2020.2
I've loaded this architectural Revit file many times. Today when I try to open it, it gets to 75% and then crashes.
5 REPLIES 5
audit before opening
Same issue. It gets to 75% and crashes. I looked at Task Manager just before it crashes. Is it a memory issue?
I uninstalled Revit 2020.
I reinstalled Revit 2020.
Phase 1 is 762 MB
Phase 2 is 251 MB
ID is 714 MBH
Structural is 265 MB
Elecatrical is 183 MB
Fire is 81 MB
So I moved everything but Phase 1 into a subfolder. I was able to open Phase 1. Then I mapped in Phase 2. It works.
Hooray.
Thank you for your tip about moving links.
RobRocks
in reply to: DarrenLowe5325
Is it a cloud project? Clear your collaboration cache.
Is it a local workshared project? Delete local files.
State of Sustainability Webinar
