Random idea, but is it possible to have a section open automatically after creating?
Hi @PieterL_TM
Thanks a lot for posting your question to the forums! Has the solution suggested by @RSomppi helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
The suggested solution does not help at all.
Often the floor plan will have tags turned off unless inserted into a sheet. Then you have to search at random where Revit has placed and figure out what Revit named that view so that you can put it into a sheet. It would handy if once your make a section cut or try to create an elevation that it would automatically open.
@curtisZG4SR wrote:The suggested solution does not help at all.
It works even if the section is not visible.
@curtisZG4SR wrote:Often the floor plan will have tags turned off unless inserted into a sheet. Then you have to search at random where Revit has placed and figure out what Revit named that view so that you can put it into a sheet.
That's a workflow problem, not a Revit one.
@curtisZG4SR wrote:It would handy if once your make a section cut or try to create an elevation that it would automatically open.
I would guess that suggestion has already been made in the IDEAS forum. You can vote it up if you'd like.
