STAIRS PROBLEM
STAIRS PROBLEM
basma_salman
Message 1 of 77
STAIRS PROBLEM
basma_salman
hello,
I am trying to create single step, but it is showing like in img below, it is extending beyond the tread,
I tried to change the connection method, the presentation is not correct
Accepted solutions (3)
Replies (76)
Message 21 of 77
Message 22 of 77
@ToanDN: Did you resolve the same way? Convert to Sketch?
Message 23 of 77
basma_salman
what abt the other 2 steps, one is 300 and the other is 350
Message 24 of 77
No. But it maybe a better solution than mine.
Message 25 of 77
This was actually a booger for me.  I'm embarrassed.  Convert to Sketch was the way to go.  All downhill from there.
Message 26 of 77
basma_salman
one more thing guys, do u know how to deal with such situation
Message 27 of 77
Uncheck End with Riser.
Message 28 of 77
HA! That's exactly what I was fighting. The built-in component stair intelligence.  Convert to Sketch and be done with it.
Message 29 of 77
basma_salman
but in real situation we do have a riser with nosing no a slab edge
Message 30 of 77
basma_salman
ok I will try to convert to sketch👍
Message 31 of 77
I need an illustration to follow this one.
Message 32 of 77
basma_salman
I guess it should look like this
Message 33 of 77
I get it. End with Tread or fasten non-slip nosing to landing as a separate component or use no landing nosing.
Message 34 of 77
basma_salman
how can I do end with tread, u mean I just model it as a component not as a stair component
Message 35 of 77
Like this?
Message 36 of 77
With your single step? You can't. You wouldn't to want to either.  You're fine without a nosing. What do you have there anyways? A door threshold? Well, there's your "nosing".
Message 37 of 77
MostafaElashmawy
check below screen shot for explanation. The notch length should be considered in the total tread depth. if you want it to show as you desire. only change the tread depth to 200mm.
Mostafa Elashmawy
Message 38 of 77
Can you set Connection Method to Straight Cut and resolve the "jut" seen in Section?  I couldn't.
Message 39 of 77
MostafaElashmawy
For the two steps stair, you can follow below configuration of notch.
Mostafa Elashmawy
Message 40 of 77
I think OP didn't have any problem with the 2-step stair.  1-step that is.
