Stairs Pattern Cannot Be Adjusted
fitrananda.24116120
Message 1 of 14
fitrananda.24116120
I'm modeling stairs and trying to align the stairs pattern to an existing floor pattern. But there is 1 tread which I can't change. Whereas in other treads & risers it can be adjusted.
Replies (13)
Message 2 of 14
Paint with Model Surface Pattern and then align the Line Work of the Model Pattern.
Align the Surface Pattern on a Model Element | Revit 2019 | Autodesk Knowledge Network
...it looks like you have it highlighted in your screenshot. Are you saying it won't nudge using the Arrow Keys?
Message 3 of 14
fitrananda.24116120
that's the problem, it only can move up/down and cannot be left/right. that's why I cannot Align it to the next tread.
Message 4 of 14
Have you tried Painting the Material/Pattern onto the Surface using the Paint Tool on the Modify Tab?
Message 5 of 14
fitrananda.24116120
Yes, I Have. but still. here I send the stairs model.
Message 6 of 14
Hate to tell you, but it works on my end.
Just to confirm: you are you using the Arrow Keys; right?
Message 7 of 14
fitrananda.24116120
I am using Align tools. that weird. even after I move that to a new file, I still cannot move it.
Message 8 of 14
fitrananda.24116120
just to make sure, you change in 3D view, right? because, in-floor plan its pattern is okay, but not in 3D view
Message 9 of 14
Yes. In 3D. Aligning Tread and Riser Surface Patterns using Arrow Keys.
Message 10 of 14
RDAOU
@fitrananda.24116120
Option 1: Use the Align tool and Align the Tread and Riser to the side/Edge of the Monolithic Run... See GIF BELOW
Option 2: Use Arrow Keys (Up/Down) as suggested by Barth
Option 3: Use Paint tool to apply Material with model pattern (More Flexible with Pattern alignment)
Message 11 of 14
fitrananda.24116120
I Don't know I still cannot do so. but seeing that you can do it, then I think it's my software problem?
Message 12 of 14
fitrananda.24116120
it's the first step that I cannot align. the other is in the right place
Message 13 of 14
Restart Revit.
Message 14 of 14
fitrananda.24116120
No, so I have found the problem. you must edit the stairs pattern when the section box is off. if section box is check, then the last step won't move
