- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Usually, Revit automatically creates proper railing once I finish the stairs command. But in this case, I found that one of the runs of the railing is horizontal(not along the stairs). So I tried to edit the railing path. But when I click the finish button it displays an error saying "The Railing line must be a single connected Sketch. If you want separate pieces of Railing, create two or more separate Railing". So I cannot finish the railing. How can this be solved?
I've attached the stair file(Revit 2015).
