stairs help
stairs help
racci81
stairs help
racci81
hey ppls... need a little help with stairs sketch...
I need to get stairs on the end to run in a circle but the sketch is giving me just "Invalid sketch, can't create run by this sketch." when I try to finish and I can't figure it out... I'm alson not sure where I define levels on which to connect on sketch.... here is a screen shot of the sketch and properties  so if you can help I would be grateful and thx in advance.
constantin.stroescu
Stop the Sketch Boundary like this:
Constantin Stroescu
racci81
ty... well I don't get that the sketch is invalid now but this...
thank you for your time
martijn_pater
Try a search for recent topic posts, the exact same question was answered recently.
ennujozlagam
Try to remove the green line colour in your left side and change riser line and see if helps. Thanks
racci81
tyvm... it was the type of stairs that bugged me... works fine now and I learned something 😛 and @constantin.stroescu yes, I switched the border lines, you are right.... ty ty
ty both for your time and effort... I appreciate it
