Staircase depth
Staircase depth
yazanhijazeen
Message 1 of 11
Staircase depth
yazanhijazeen
Hallo everyone,
we have noticed in our model that the stair depth is different between top and bottom, as seen in the picture below.
As seen in the second picture, the staircase should follows the red line, so the right depth should be 20 cm.
any ideas how to fix this?
Replies (10)
Message 2 of 11
_Vijay
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 11
yazanhijazeen
the depth is already set to 20 cm,
Message 4 of 11
_Vijay
you expecting bottom and top difference width?
Vijayakumar
Head of BIM
Message 5 of 11
Notch Thickness.
Message 6 of 11
yazanhijazeen
yes exactly, as seen in the first picture i posted, you can see the difference even though the depth is set to 20 cm,
Message 7 of 11
yazanhijazeen
the Notch thickness, does not affect the stair depth.
Message 8 of 11
yazanhijazeen
so it worked,
i only had to extend a bit the width of the last step.
thank you everyone
Message 9 of 11
It doesn't??? Must be my lying eyes playing tricks on me then.  😉
Message 10 of 11
@yazanhijazeen: I don't understand what your solution was.  Can you say again?
Message 11 of 11
yazanhijazeen
@barthbradley the Notch Thickness only changed these two thicknesses as see in the picture ( First and last step ) and did not affect the depth, plus i need the thickness to stay as it is for stair design reasons.
 What i have done is that i extended the last step width ( only 2 mm). The depth is back to 20 cm, but a small part is missing as seen in the picture that would be replaced by a mass.
