Staircase depth
10 REPLIES 10
Message 1 of 11
yazanhijazeen
554 Views, 10 Replies
Staircase depth
Hallo everyone,
we have noticed in our model that the stair depth is different between top and bottom, as seen in the picture below.
As seen in the second picture, the staircase should follows the red line, so the right depth should be 20 cm.
any ideas how to fix this?
10 REPLIES 10
Message 2 of 11
_Vijay
in reply to: yazanhijazeen
Message 3 of 11
yazanhijazeen
in reply to: _Vijay
the depth is already set to 20 cm,
Message 4 of 11
_Vijay
you expecting bottom and top difference width?
Message 5 of 11
Notch Thickness.
Message 6 of 11
yazanhijazeen
in reply to: _Vijay
yes exactly, as seen in the first picture i posted, you can see the difference even though the depth is set to 20 cm,
Message 7 of 11
the Notch thickness, does not affect the stair depth.
Message 8 of 11
so it worked,
i only had to extend a bit the width of the last step.
thank you everyone
Message 9 of 11
It doesn't??? Must be my lying eyes playing tricks on me then.  😉
Message 10 of 11
@yazanhijazeen: I don't understand what your solution was.  Can you say again?
Message 11 of 11
@barthbradley the Notch Thickness only changed these two thicknesses as see in the picture ( First and last step ) and did not affect the depth, plus i need the thickness to stay as it is for stair design reasons.
 What i have done is that i extended the last step width ( only 2 mm). The depth is back to 20 cm, but a small part is missing as seen in the picture that would be replaced by a mass.
