stair tread and stringer alignment
9 REPLIES 9
Message 1 of 10
mark.jollyR7W78
602 Views, 9 Replies
I'm trying to move a channel stringer up to align with the edge of the treads. The stringer needs to remain a 150 deep PFC stringer. It's okay for the tread to sit below the stringer as it's for an access stair.
Currently working in Revit 2020.
Tags (3)
Labels (1)
9 REPLIES 9
Message 2 of 10
It might be possible to do what you want by editing the stringer profile and creating the offset there.
Message 3 of 10
Message 4 of 10
se.ha
in reply to: mark.jollyR7W78
I think you can get there by adjusting the nosing profile of the run. Might need some tweaking to find the right amount and keep the depth of 150
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Message 5 of 10
Hadn't thought of this but when I tried offsetting a stair support profile which had no affect.
Message 6 of 10
When you enter a value for 'structural depth on run' it drops the stringer (support) down. Values have to be 0 or greater.
Message 7 of 10
mark.jollyR7W78
in reply to: se.ha
You appear to have hit upon a possible solution but I can't replicate what you've shown. Would you mind sending a file to interrogate please?
Message 8 of 10
Message 9 of 10
se.ha
All I did was changing the nosing length in the run type properties. File is attached. Quick and dirty without renaming properly...
se.ha
Message 10 of 10
