Does anyone know how I can get a similar result for my ceiling ?
5 ANTWORTEN 5
Nachricht 1 von 6
AUTOCYAS
250 Aufrufe, 5 Antworten
I've been searching for some tutorials on youtube that would help me drawing a ceiling similar to this.
I can't find anything, does anyone have a link or something ?
That would be really helpful, thanks a lot.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: AUTOCYAS
Create a normal flat ceiling then add in-place model sweeps on it.
Nachricht 3 von 6
Yien_Chao
hi
if you want just a custom line pattern, PyRevit has a good pattern generator.
if you want a thickness for your pattern, i suggest a simple family by extrusion on ceiling.
Nachricht 4 von 6
Fundamentally, those are Sweeps.  Several ways to do them.  You could model them In-Place.  Perhaps, draw the design  with Model Lines on the Work Plane first, and then in In-Place Modeling Mode, select the Model Lines as your Sweep Paths.
...the key here would be creating and setting the Work Plane to draw on.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M...
Nachricht 5 von 6
AUTOCYAS
als Antwort auf: barthbradley
Thanks a lot! I'm going to do this now :grinsendes_Gesicht:
Nachricht 6 von 6
AUTOCYAS
als Antwort auf: Yien_Chao
Thank you! I haven't heard of PyRevit before, thanks for the tip
