Stair run material is not consistent
vsalimiGRMK9
Message 1 of 8
vsalimiGRMK9
Hi everybody,
Does anyone know why the stair attached is not consistent in material? Run does not follow the material assigned. Even a single run is showing different materials in a single piece.
Replies (7)
Message 2 of 8
Did it get painted?
Message 3 of 8
vsalimiGRMK9
No, the Revit file is attached. That's the cut pattern that has issue. We cannot paint the cut pattern.
Message 4 of 8
I don't know how you managed to create that stair.  Maybe just redraw it.
Message 5 of 8
RDAOU
@vsalimiGRMK9
It is using a different monolithic material
  • Edit the Stair Type >>> Under Construction >>> Edit Landing Type >>> Set the Monolithic Material By Category
Message 6 of 8
vsalimiGRMK9
Thank you for your comment, yes we could redraw it. But, I need to know why this happens.
Message 7 of 8
vsalimiGRMK9
Applying <By Category> assigns the material defined for stairs in Object Style. However, I want its material to be different from the material in Object Style.
Message 8 of 8
RDAOU
@vsalimiGRMK9
Reason is the paint you applied to the top face of the Stair as well as the sides of the run which conflicting with the Monolithic Material...To fix:
Option 1: Go to Material Editor and Set the patterns (Surface as well as Cut) in the PAC Concrete material u used to paint stairs
Option 2: Remove the paint, and simply use the PAC Concrete or Any other Material as Monolithic Material and it should also work fine
