Stair numbering
Stair numbering
e_inan58
Stair numbering
e_inan58
When i was stair numbering, dont start firt number in first tread.
how i fix that?
RDAOU
@e_inan58
Try Either of the following
  • Option 1: Use the Tab key to select the RUN then check the box "Begin with Riser"
  • Option 2: If stair run should not start with riser...Select the numbering annotation and change it to Treads instead of risers
e_inan58
when i do the first option it still doesn't fix
Note: I created the stair with a sketch
RDAOU
@e_inan58
Can you attach the Revit file? maybe someone can have a look at instead of guessing
PS: you can copy the stairs and paste in a new file if you cannot share all the model
e_inan58
There are a few more things I want to say:
-I don't know English very well. That's why I use google translate.
-I'm just trying to learn the program. There's a lot I don't know yet.
-I'm using version 2022, hope it's ok
RDAOU
@e_inan58
No problem you do not need to worry about all that ...
The stairs...it is the risers distribution which is causing that. What you can do is
  1. Start the stair and use from the tools the U Shaped Winder
  2. Set the necessary values (15 steps, and depth of the tread)
  3. Place it and Finish
  4. Then Convert to Sketch and adjust the Borders to meet the dimensions you need
When I'm back in the office I will post an additional GIF showing steps to follow in case you did not manage. In the meantime if it works, do not hesitate to mark as solution
