I have 2 panels. I want to set the meterialproperty as follow:
panel 1 (see pict 1): green flat appearance in 3d-model, and gray flat appearance in 2d revit-sheet
panel 2 (see pict 2): green flat appearance in 3d-model, and crosshatch (black-white) in 2d revit-sheet
Question:
Something is wrong with the setting of the both panels. Does anyone know how I can fix to the wished materialproperty?
Kind regards,
peter smith
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Same applies to both Panels
To show the green color:
To show second view (the section) to show gray while the first remain green:
The result of the last one exactly what I want.
Is it possible to arrange this overrule setting in the material property, because there are a lot different paneltypes in a project?
You can set up the Override By Category (of by filter) and add/use that in a view template
Example:
When you apply it to the Section views they will all be overridden (See GIF below)
Thx for the explanation. I already used viewtemplate for the elevation drawing.
If the appearance panel in the 2d sheet has to be adjusted to another colour, than I have to use "filter" function.
Isn't it?
Kind regards,
peter smith
You override elements on views and place views on sheets...meaning whatever override by filter or by any means is applied to the view
