Stair Disconnect Levels Not work
GHASEM_ARIYANI
Advisor Advisor
Message 1 of 12
GHASEM_ARIYANI
Hello
Stair Disconnect Levels Not work? this is a bug?
GHASEM ARIYANI
BIM/VDC Manager
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Replies (11)
Message 2 of 12
PijPiwo
Can you upload this rvt file?
Message 3 of 12
GHASEM_ARIYANI
hello and thank you
file RVT 2018 Attached.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 4 of 12
PijPiwo
Must be a local glitch on your end or something about your stair settings that revit doesn't like. It doesn’t work with precast nor with cast-in-place, but it does work with assembled stair, and all works fine in a new, fresh project file.
Message 5 of 12
GHASEM_ARIYANI
hello and thank you
Yes i know, but i need only cast-in-place.
Why not work for the case in place stair?
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 6 of 12
PijPiwo
Sorry, can't make it work. I'd send the file to AD, let them take a look at it.
Message 7 of 12
ennujozlagam
@GHASEM_ARIYANI hello, it looks like it's only working in assembled stair, not on the precast stair and cast-in-place stair. its looks like a bug.
Hello, Autodesk please take a look in this issue.. thanks
Message 8 of 12
What is your trick?  I cannot get Monolithic and Precast stairs to disconnect levels in a new, fresh project from the OOTB template.  I had to unpin and delete them manually.
Message 9 of 12
GHASEM_ARIYANI
This is a bug
We hope to soon be resolved
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 10 of 12
PijPiwo
@ToanDN, it doesn't work now, WTF!!!???
Message 11 of 12
I thought I struck gold learning some cool trick from you @PijPiwo.
While waiting for the fix that may or may not be coming, either change the stairs to assembled, disconnect levels, and change back to original type; or just unpin and delete for the levels to be excluded.
Message 12 of 12
chikamaka
Observer
Observer
Hi. I had the same problem. And probably it is a bug. But there is a solutioun how i made. The level whic you want to disconnect, change its height then revit will show fail on stairs. And now disconnect. It works!!!
