Stair Disconnect Levels Not work
GHASEM_ARIYANI
Advisor Advisor
Message 1 of 12
GHASEM_ARIYANI
Hello
Stair Disconnect Levels Not work? this is a bug?
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Replies (11)
Message 2 of 12
PijPiwo
Can you upload this rvt file?
Message 3 of 12
GHASEM_ARIYANI
hello and thank you
file RVT 2018 Attached.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 4 of 12
PijPiwo
Must be a local glitch on your end or something about your stair settings that revit doesn't like. It doesn’t work with precast nor with cast-in-place, but it does work with assembled stair, and all works fine in a new, fresh project file.
Message 5 of 12
GHASEM_ARIYANI
hello and thank you
Yes i know, but i need only cast-in-place.
Why not work for the case in place stair?
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 6 of 12
PijPiwo
Sorry, can't make it work. I'd send the file to AD, let them take a look at it.
Message 7 of 12
ennujozlagam
@GHASEM_ARIYANI hello, it looks like it's only working in assembled stair, not on the precast stair and cast-in-place stair. its looks like a bug.
Hello, Autodesk please take a look in this issue.. thanks
Message 8 of 12
What is your trick?  I cannot get Monolithic and Precast stairs to disconnect levels in a new, fresh project from the OOTB template.  I had to unpin and delete them manually.
Message 9 of 12
GHASEM_ARIYANI
This is a bug
We hope to soon be resolved
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 10 of 12
PijPiwo
@ToanDN, it doesn't work now, WTF!!!???
Message 11 of 12
I thought I struck gold learning some cool trick from you @PijPiwo.
While waiting for the fix that may or may not be coming, either change the stairs to assembled, disconnect levels, and change back to original type; or just unpin and delete for the levels to be excluded.
Message 12 of 12
chikamaka
Observer
Observer
Hi. I had the same problem. And probably it is a bug. But there is a solutioun how i made. The level whic you want to disconnect, change its height then revit will show fail on stairs. And now disconnect. It works!!!
