stair arrow
7 REPLIES 7
Message 1 of 8
hliS658H
1556 Views, 7 Replies
stair arrow
How can I have a continuous arrow line instead of two arrows for stairs as shown in the image? Thank you.stairs arrow.jpg
7 REPLIES 7
Message 2 of 8
mostafa2414
in reply to: hliS658H
Message 3 of 8
eng.mostafa2414
Your landing don't have a stair path. it seams that you made it by sketch.
select stair then click on edit stair, then select the landing and click edit sketch then draw a stair path at the landing connecting the two stair paths at each run.
https://knowledge.autodesk.com/community/screencast/7909e966-5c0f-4859-9e38-6201286ed6c4
You should also make sure that the level of the landing is correct.
Mostafa Elashmawy
Message 4 of 8
hliS658H
in reply to: eng.mostafa2414
whewww
when I followed your steps to edit the stair path, as you can see, there is a path for landing there, and it didn't solve the issue - still two separate arrows.
Message 5 of 8
eng.mostafa2414
As I mentioned in my email, you should make sure that the level of the landing is correct.
Are you able to share the stair? send a file with the stair only.
Mostafa Elashmawy
Message 6 of 8
hliS658H
What do you mean by landing level? I created the landing by automatic landing when created the stairs. I don't know how to share the stairs only, it is in a huge project, tried to copy paste, it didn't work, unless I create one as a new file, maybe I will try that later.
Message 7 of 8
eng.mostafa2414
Please refer to the solution at attached thread.
I think it's same situation.
https://forums.autodesk.com/t5/revit-architecture-forum/stair-paths/td-p/6359193
Mostafa Elashmawy
Message 8 of 8
hliS658H
Thank you for your screencast! However, I just realized nothing wrong with the stairs or landing I made, it is the up/down direction, after I changed the type to automatic up/down direction, I got it right.stairs arrow.jpg
Forma Design Contest
Technology Administrators
