Stair and Reference Planes in Revit 2018
3 REPLIES 3
MunirH
825 Views, 3 Replies
Hi Everyone ...
I am using Revit 2018 .... I started Stair command and input Reference Planes in Ground Floor (level 0.00) ... everything went smooth. I went to the First Floor (level 4000 mm) I did the same procedure I started Stair command, started to input Reference Planes ... error message .... I tried this procedure on other files .... same result .... I did that using Stair by Component in Revit 2017 ... No Error ....
Can anybody help me please
3 REPLIES 3
__________________________
Claus Chaverri-Sievert
Technical Support Specialist
San José, Costa Rica
www.autodesk.com
Please upload a screencast (alternative) in order to see the steps you have taken before the error appears. I follow the steps you mentioned but I did not see the error.
If you used the Pick Line Tool, a hotfix has been issued very recently.  Download it and check if the Revit 2018 hotfix (2018.0.1) resolves also this issue.
Here are the instructions on how to install it.
www.autodesk.com
MunirH
in reply to: MunirH
I downloaded the hotfix .... everything is OK right now ... the error disappeared .... Thanks
Forma Design Contest
