Hi Everyone ...
I am using Revit 2018 .... I started Stair command and input Reference Planes in Ground Floor (level 0.00) ... everything went smooth. I went to the First Floor (level 4000 mm) I did the same procedure I started Stair command, started to input Reference Planes ... error message .... I tried this procedure on other files .... same result .... I did that using Stair by Component in Revit 2017 ... No Error ....
Can anybody help me please
Solved by claudio.chaverri.sievert. Go to Solution.
Please upload a screencast (alternative) in order to see the steps you have taken before the error appears. I follow the steps you mentioned but I did not see the error.
If you used the Pick Line Tool, a hotfix has been issued very recently. Download it and check if the Revit 2018 hotfix (2018.0.1) resolves also this issue.
Here are the instructions on how to install it.
