Stacked Walls area calculation error
Message 1 of 15
There is an error if the area calculation.
If you draw a stacked wall with an unconnected height of 20' and you make it 70' long. Then attach the top to a roof 10' high.
The area should be 700 SF. But Revit will tell you it is 1400 SF.
This only happens with stacked walls. other walls seem to calculate properly, and if you edit the profile of the wall it seems to calculate properly.
Revit version 2017.2.3
10.0.1150.0
20171027_0315(x64)
I have not tried this in 2015 or 2016 or 2018
Jeff Rath
Bim Manager
Coover Clark
Replies (14)
Message 2 of 15
Sahay_R
This is what I got with 2018
This is also what I got in 2017
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 15
I created the same exact problem in 2018 my 70'-6" long by 10 high wall has an area of 1400 SF
Message 4 of 15
Sahay_R
Your wall is unconnected and not constrained to level 2, which is where my roof was. Compare the differences between your screenshot and mine.
Rina Sahay
Message 5 of 15
I can replicate the behavior if the wall is Unconnected, see the 1st and 2nd screenshots.  To fix it, you need to change the stacked wall to Connected, see screenshot 3.
Message 6 of 15
I created the same problem in 2016 as well
Message 7 of 15
When I make the wall connected to a height then it calculates to the connected height and not to the roof.
Message 8 of 15
that only works if the level and the roof are the same ... what about a sloped roof .... FAIL
Message 9 of 15
Remember this does not fail with other wall types
Jeff Rath
Bim Manager
Coover Clark
Message 10 of 15
You are correct.  It does sound like a bug.  The only way I can think of is using Edit Profile instead of attaching to Roof.
Message 11 of 15
Ya ... I figured out the edit profile part
But if you move the roof then the wall is wrong ...
Message 12 of 15
Sahay_R
I got my results with stacked wall connected to a flat roof.
Rina Sahay
Message 13 of 15
So this is a bug in 16, 17, and 18 ...
Something that needs to be fixed
Message 14 of 15
Lock the profile line to the roof plane.
Message 15 of 15
This is still a software bug. No solution. Just workarounds.
Autodesk needs to fix this.
