SPOT SLOPE NOT READING GREATER THAN 12
jledgewood409
Message 1 of 15
jledgewood409
i have roof pitches that are 16"/12". when i place a spot slope on said roof it reads the 16" as something else. i am including a screen shot that shows the spot slope and the dimensions that read the correct slope.
Replies (14)
Message 2 of 15
Change reported units for slope? Project Unit=>Slope, or under the Type Parameters for the Family.
...sounds like want a ratio:12 , not rise:run
Message 3 of 15
Works here.  What are the Spot slope type settings?
Message 4 of 15
jledgewood409
the slope ratio that you have hi-lighted matches mine. I am not sure what in the type settings that you are asking me about?
Message 5 of 15
Select the Spot Slope and Edit Type.
Message 6 of 15
jledgewood409
I am attaching a screen shot of the spot slope type properties
Message 7 of 15
Still can't replicate it.  You may need to share a revit file.
Message 8 of 15
is that a 22 1/2" : 12" Roof Slope, @ToanDN?  A 16":12" Roof Slope is 11 3/4"or 75% of 12".
Message 9 of 15
No it is a 16"-per-foot sloped roof.
Message 10 of 15
Message 11 of 15
Left is 16"-per-foot, right is 9"-per-foot.  What are you trying to say?
Message 12 of 15
Message 13 of 15
Any guesses @ToanDN? Voodoo Magic? Not quite...
...yes, the spot annotation is real; not faked
Message 14 of 15
I know - placed on surfaces versus placed on the edge between 2 sloped surfaces.
@jledgewood409  you got it, bud?  what you see is a spot elevation reporting the intersection of 2 sloped planes of a roof.
Message 15 of 15
@jledgewood409: Use the tab key to select the right surface when placing your slope annotation. Currently it's referencing the hip slope.
