Dear All
Kindly please inform me how can i show my spot elevation value as minus or plus in my plan view.
Waiting for your valuable reply
Thanks in advance
Solved by revit1980. Go to Solution.
A negative number will be displayed if the base from which the elevation is determined is above the annotated element. In that case, the spot elevation might show something like -5.00
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Thank you for your quick reply.It is okay I am doing what you mentioned.
I dont have any problem with the negative numbers.They are ok.
but + not shown for the positivite values.
ok
Andrej Ilić
MSc Arch
Dear Doctor Grozozo
I found my aswer. I am sharing below photo.Maybe others require.
