Spot Elevation
4 REPLIES 4
revit1980
1164 Views, 4 Replies
Spot Elevation
Dear All
Kindly please inform me how can i show my spot elevation value as minus or plus in my plan view.
Waiting for your valuable reply
Thanks in advance
4 REPLIES 4
Ilic.Andrej
in reply to: revit1980
A negative number will be displayed if the base from which the elevation is determined is above the annotated element. In that case, the spot elevation might show something like -5.00
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
revit1980
in reply to: Ilic.Andrej
Thank you for your quick reply.It is okay I am doing what you mentioned.
I dont have any problem with the negative numbers.They are ok.
but + not shown for the positivite values.
Ilic.Andrej
ok
Andrej Ilić
MSc Arch
revit1980
Dear
I found my aswer. I am sharing below photo.Maybe others require.
Forma Design Contest
