Split segment not working
Message 1 of 20
Trying to use the split segment tool to adjust my elevation. I get the exacto knife cursor but it won't do anything when I click on the elevation line. Any idea why?
Replies (19)
Message 2 of 20
Sahay_R
Are you cutting through the elevation line that goes through the bubble?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 20
Viveka_CD
Hi @Anonymous
Can you check if your view is pinned? This may disable the tool.
Message 4 of 20
No, it isn't pinned. Good idea to check, though.
Message 5 of 20
I'm not sure what bubble you're talking about. I don't have a bubble. I'm using 2016.
Message 6 of 20
@Anonymous
Can you share a more generous screenshot, showing the elevation, view, and possibly the view's properties?
Message 7 of 20
Sahay_R
@Anonymous 2016 also has elevation bubbles. When you start, you will see them in the plan view.
Rina Sahay
Message 8 of 20
Corsten.Au
Hi
Split the Elevation View in " PLAN VIEW "
You cannot split the Elevation view in the Elevation itself..
go to plan, select view ( Ex View:Elevation:North) , select " Split Segment "
this should work..
Cheers!
( If this doesn't work for the project, then just check in new project from the scratch and see how it works... )
Corsten
Building Designer
Message 9 of 20
@Corsten.Au: you sure about that?
Message 10 of 20
Corsten.Au
1. If the view is a Call out, then probably Revit wont allow to split it.. Please check that..
2. the snapshot attached in the main question...
its shows " Size crop " and  " Split segment " active.. ( not greyed out )
If " Split Segment " command is selected (active ), it should greyed out .
@barthbradley Overall am just giving my best guess.. 🙂
Corsten
Building Designer
Message 11 of 20
FAIR59
if the view is a dependant view, you can't split the (dependant ) view. Revit goes through the motions, but changes nothing. You have the split the "parent" view.
Message 12 of 20
Corsten.Au
Hi
I think I Cracked the solution this time...
The Extents of elevation should be inside ( within ) the Crop Region.
Otherwise Revit doesn't allow to split...
( Now this is not the standard setting in Revit, different versions of Revit behaving differently )
Am pretty sure you are facing this situation..
Let us know
Cheers!
Corsten
Building Designer
Message 13 of 20
@Corsten.Au: Good one! Smiley Wink
Message 14 of 20
m_byrum
Depth clipping needs to be set to "No Clip".
Message 15 of 20
Thanks! i was trying to do it in dependant view and now i know!
Message 16 of 20
maura.witzelHDR
Thank you for sharing this!!
Message 17 of 20
ryanc3DR3S
I just had the same issue, this was the issue. Thank you!
Message 18 of 20
ubald_urbanMMU23
Community Visitor
Community Visitor
It worked for me! Thanks a lot!
Message 19 of 20
rcampbell
Observer
Observer
had this issue in Revit23 and this was still my solution, thanks!
Message 20 of 20
mjonesZ7ZXY
amazing! thank you
