Hi Community
I am trying to split a section and displace it up to cut through a door but when I do so it is not letting me do it and giving me this no parking like sign
Solved by RDAOU. Go to Solution.
How far are you trying to drag it?...it won't let you drag beyond the far clip distance
Set section to no clip or increase the far clip
Maybe you move the segment farther than the Far Clip Offset. Try increase Far Clip Offset value or change Far Clipping to No Clip and see if you can do it.
