Some level is not showing in section when the section is located inside the building. The level is showing when section cuts vertically and when having a certain angle but when the section is cut horizontally some section is not showing. Also when I relocate the section outside levels will show up. Send help Thanks.
Solved by jay_colcombe. Go to Solution.
This would indicate that the levels may not be crossing the Section Line!
Check in the Elevations that the Levels pass through the Section
