Some level not showing in section
2 REPLIES 2
Clyndr
463 Views, 2 Replies
Some level is not showing in section when the section is located inside the building. The level is showing when section cuts vertically and when having a certain angle but when the section is cut horizontally some section is not showing. Also when I relocate the section outside levels will show up. Send help Thanks.
2 REPLIES 2
jay_colcombe
in reply to: Clyndr
This would indicate that the levels may not be crossing the Section Line!
Check in the Elevations that the Levels pass through the Section
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Levels-are-not-vis...
Jay Colcombe
Autodesk Certified Instructor
Clyndr
in reply to: jay_colcombe
Thank you
Forma Design Contest
