Hi everybody,
I am having an issue here. I want to place some skylights on a sloped roof.
I am relatively new to Revit although have already a good grip of the program.
I have used the standard skylight from Revit. So the skylight shows properly in section, but it won´t appear sectioned on plan.
Please I will be very happy to hear your thoughts.
Cris
Solved by ToanDN. Go to Solution.
Of course. Here you have! It´s the one from Revit libraries
Edit the family and change the category from Windows to Generic Models.
Toan Nguyen
This is a good fix for aesthetic purposes, but once turned into a generic model, you can no longer attach a window tag, or it will not appear within a window schedule. Is there another solution other than changing the type to a generic model? Thanks in advance.
