Skylight won´t appear sectioned on plan view
7 REPLIES 7
Message 1 of 8
cristina_puya
427 Views, 7 Replies
Hi everybody,
I am having an issue here. I want to place some skylights on a sloped roof.
I am relatively new to Revit although have already a good grip of the program.
I have used the standard skylight from Revit. So the skylight shows properly in section, but it won´t appear sectioned on plan.
Please I will be very happy to hear your thoughts.
Cris
7 REPLIES 7
Message 2 of 8
oladamilola
in reply to: cristina_puya
Do you mind sharing the family you're using ?
Message 3 of 8
cristina_puya
in reply to: oladamilola
Of course. Here you have! It´s the one from Revit libraries
Message 4 of 8
Edit the family and change the category from Windows to Generic Models.
Message 5 of 8
Thanks! Problem solved!! 😊
Message 6 of 8
mb
Observer
in reply to: ToanDN
This is a good fix for aesthetic purposes, but once turned into a generic model, you can no longer attach a window tag, or it will not appear within a window schedule. Is there another solution other than changing the type to a generic model? Thanks in advance.
Message 7 of 8
in reply to: mb
Share it and Nest it into a Generic Template.
Message 8 of 8
mb
Observer
in reply to: barthbradley
Thank you for noting barthbradley. I tried creating a generic roof family whilst nesting the window family within it. Unfortunately, it comes to the same outcome. I am using The Rooflight Co's own BIM library. Any further suggestions would be most welcomed.
Forma Design Contest
