See the small arched bridge in the reference image below. I'd like to model this accurately if possible. Is there a way to use an array or beam system that is able to follow the arch?
Solved by ToanDN. Go to Solution.
Seems overkill but if you insist.
Toan Nguyen
@BigPicture045 wrote:
How do make that? Is that a wall?
Arch Roof by Extrusion, change to Sloped Glazing as per the screenshot indicates. Change mullion type to the size as you need.
Toan Nguyen
@BigPicture045 wrote:Oh yeah! My first bridge. Thanks.
Kind of looks like a Curtain Wall gone wrong to me. But, whatever. 😉
...actually, that was pretty clever, @ToanDN.
