@Anonymous wrote:How can real gps coordinates be input into revit site plan?
Here's a post that explains it: http://www.revitforum.org/architecture-general-revit-questions/17152-specify-coordinates-point.html
Import a survey DWG file and use Acquire Coordinates. That will adjust Revit's Shared Coordinate system to align with the WCS of the source DWG file. Alternatively if you know the exact coordinates and elevation of a specific location in your model you can use Specify Coordinates at Point (SCaP) and enter the relevant information. You can use Rotate True North to rotate the model into alignment with True North, use the same location used for SCaP to rotate the model from.
Steve Stafford
