Multiple Toposurfaces and m3
To whom it may concern,
I have two questions from Revit 2017. I just started with a model of a 3-storey office building with a basement on an extremely irregular site. I am banging my head about the following two issues:
- Placing walls on a basement floorplan
- Creating a toposurface from an imported 2D AutoCAD file
I imported the basement and the first floor from AutoCAD. The basement is located at height = -4.50 m, and the first floor is located at height = 0.00 m. I placed the basement at -4.50 m, but I did not place it at SITE view. I switched to an ELEVATION view, copied a new floor, named placed it at -4.50 m. I created walls in what I called “BASEMENT.” The basement is not completely buried into the ground. The entire envelope of this basement has contact to the exterior air, not with the earth. The first issue was that I could not select and edit the material of an existing exterior wall. I did it 3 to 4 times, the Revit crashed, and an error was shown (“the driver has experienced an error…”). The only wall I could choose and edit was a Retaining Concrete Wall. I am not sure if this is right. Is it logical the error message showed by the software? Can I go ahead and keep choosing the Retaining Concrete Wall?
Then, I continued with most of the walls (using the edited Retaining Concrete Wall) in the “BASEMENT” floorplan. But, I decided to create the toposurface of the site before I keep going to the top floor. Let me give you a general picture. There are two “valleys” in the site. The basement, which is divided in two bodies, is located inside these two “valleys”. Firstly, I selected the “BASEMENT” view, but I could not create the toposurface. Then, I tried the “FIRST FLOOR” and nothing happened. Finally, when I tried the SITE view, I could create one layer of the toposurface. Should I have created the toposurface and the walls of the basement in the SITE view? Is there another option to solve the toposurface? Can I do the toposurface in a second file, and import it to the current file? If this is right, where should I put it? Will it be on the SITE or the BASEMENT floor?
Please, could you give me some suggestions? Any comments will be highly appreciated!
José Luis Bermúdez Alcocer, Ph.D., M.Arch, B.Arch.
