Showing surface pattern in schedule
vanessa_prawira3GFWF
Message 1 of 8
I am trying to create a floor schedule to count the total area. Each floor has their own surface pattern. Is there anyway to show the surface pattern in schedule?
Currently I am using legend, but with legend I have to input the area manually
This is what I did using legend
Replies (7)
Message 2 of 8
ennujozlagam
https://help.autodesk.com/view/RVTLT/2024/ENU/?guid=GUID-E6629462-3D83-4296-9309-8C704F576DEA
Message 3 of 8
I still don't see how I am supposed to show the surface pattern. Am I missing something?
Message 4 of 8
Message 5 of 8
What about using the Image Parameter?
Message 6 of 8
That could work, but I would like to know is there any other way that I could make use of the material parameter that I have already set up before
Message 7 of 8
Make use of the Material Parameter you set up before?  Tell me more about this Parameter.
Message 8 of 8
Sorry, I'm referring to the surface pattern of the materials. I have 13 different floor types, each one has its own material with its own surface pattern. If I use images, it kinda defeats the purpose of having carefully chosen different surface pattern for each one.
