Showing sunlight in interior of model for Sun Study
claudiaharach11
Observer Observer
claudiaharach11
Observer
Observer
Hi there,
I am currently doing a sun study in Revit but when I turn on sun and turn on shadow I can't see the sun through the doors and windows inside my building model, it only shows shadows outside. How would I fix this?
Is this an exterior or interior view?
claudiaharach11
Observer
Observer
This is a plan cut where the eye elevation was set to 850mm high.
You are not going to have a correct presentation of the shadow because Revit will consider everything is cut off at 850 mm (850 mm tall walls etc...).
claudiaharach11
Observer
Observer
Ok thank you. Do You know what I would need to change in the settings?
Use a 3d top view, hide the roof, and see if it works okay enough.  You will have a correct shadow of the walls and windows, but no shadow by the roof.
Then you can overlay that view and a floor plan view on sheet if you need to show doors and windows
Create Camera Views.
