deleted
9 ANTWORTEN 9
Nachricht 1 von 10
hannahBPS
460 Aufrufe, 9 Antworten
deleted
deleted
9 ANTWORTEN 9
Nachricht 2 von 10
mhiserZFHXS
als Antwort auf: hannahBPS
Scratch what I wrote before.
Draw one reference line between lines A and B, where the base of your extrusion is now. Use trig to control the sides of that little triangle you now have so that the new line is always 1 1/2" and constrain your extrusion to the new line.
Nachricht 3 von 10
Maybe I misunderstood but what you are asking cannot be done with what you show.  The shape can only move within a limited range (see the 1.5" R blue circle) until it will disconnect from ref B.  Maybe show a sketch of your end goal instead of piecemeal information then we may suggest a different approach overall.
Nachricht 4 von 10
mhiserZFHXS
als Antwort auf: ToanDN
@ToanDN
Not if it rotates, which is what I interpreted, but maybe I'm wrong?
Nachricht 5 von 10
als Antwort auf: mhiserZFHXS
@mhiserZFHXS wrote:
@ToanDN
It doesn't matter if the shape rotates or not.  1.5" from the intersection of the 2 ref planes is the limit.
Nachricht 6 von 10
mhiserZFHXS
It's not 1 1/2 inches from the intersection. It's just a 1 1/2" line between those two planes. There are an infinite number of ways that could be oriented.
Nachricht 7 von 10
Oriented, yes.  But neither of the two corners can be more than 1.5" from the intersection.  Feel free to correct me by showing a sketch of a such condition.
Nachricht 8 von 10
Post a photograph of this pergola you are trying to model, as well as your RFA.  Maybe then we can help you find a solution.  Right now, you are only giving us a puzzle piece that may or may not fit - or even belong.  Know what I mean?
Nachricht 9 von 10
mhiserZFHXS
@ToanDN
Ah, yea, but I don't THINK that's OP's intention. But I don't know since they've gone quiet.
Nachricht 10 von 10
@mhiserZFHXS wrote:
@ToanDN
OP has not only gone quiet but has deleted post.   Too bad. I was really curious to know what that puzzle piece was all about.  :zwinkerndes_Gesicht:
