Hi there,
I am currently doing a sun study in Revit but when I turn on sun and turn on shadow I can't see the sun through the doors and windows inside my building model, it only shows shadows outside. How would I fix this?
You are not going to have a correct presentation of the shadow because Revit will consider everything is cut off at 850 mm (850 mm tall walls etc...).
Use a 3d top view, hide the roof, and see if it works okay enough. You will have a correct shadow of the walls and windows, but no shadow by the roof.
Then you can overlay that view and a floor plan view on sheet if you need to show doors and windows
