- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Revit LT
I inserted a CAD survey plan at ground level that is visible in all views (which is also good for 3d views etc)
when I go to the upper floors I can only see this cad plan if I set the view range to unlimited.
However I only want to see each floor and not the floor below, but i do want to see the CAD plan as a background in
all levels.
I dont want to copy the cad plan to other levels as then I need to hide it in all sections, 3ds etc.
is there an easy way to achieve this?
