Empty system panel download
Message 1 of 17
I require a empty system panel, and it appears this hasn't been available int he library since 2017, would it be possible to get a download or is there a work around? Thanks!
Replies (16)
Message 2 of 17
hmunsell
what do yo mean by Empty System Panel?
C:\ProgramData\Autodesk\RVT 2020\Libraries\US Imperial\Electrical\Architectural\Electrical Power\Distribution\Electrical Panel.rfa ?
Howard Munsell
Message 3 of 17
It would be impossible for the Empty System Panel to be missing from the Project.  If you are not seeing any TYPES listed under Empty System Panel, right-click on it and press "New Type".
Message 4 of 17
hmunsell
LOL, i was helping someone out earlier with electrical issues so when i saw System Panel my brain automatically thought electrical. didn't even thing Curtain Panel.
Howard Munsell
Message 5 of 17
Actually, I'm not so sure I answered the OP's question.  Maybe you're right.
Message 6 of 17
ennujozlagam
try this edit your system panel family like screenshot below delete the panel and saveas as empty system family and load into your project and see if helps. thanks
Message 7 of 17
Sorry I should have made the question a bit clearer. Basically I'm using curtain walling to create a timber screen, so naturally I would just set the curtain panel to empty, however the the revits since 2017 haven't included a system panel - empty they just include a curtain panel - empty system panel. The curtain panel - empty system panel wont work on any other panel shape other than rectangular from experience. this link may explain it better? https://revitforum.org/showthread.php/30744-Empty-System-Panel-is-missing-(Revit-2017)?p=169398
The image below is the timber screen I'm trying to model, and the angle at the top means the panel cannot be empty and is instead either the solid or glazed by default.
Message 8 of 17
bin
You can try Beam System
Message 9 of 17
Awesome thankyou! Ill give that a go!
Message 10 of 17
bin
https://youtu.be/APMlVfRn810
Here's a quick video for you.
Message 11 of 17
I have no idea what you are talking about when you say "empty system panel wont work on any other panel shape other than rectangular from experience."
Message 12 of 17
...here's 96 more for you:
Message 13 of 17
...if the construction is stick-framed, wouldn't there be blankets between the studs?
Message 14 of 17
I agree you can make non rectangular panels, but the panels you have shown are glazed, in my experience if you try to change one of those panels to empty (hence empty system panel) it wont work in the non rectangular shapes.
Message 15 of 17
@Anonymous wrote:
...in my experience...
Listen and learn, @Anonymous: those 184 panels shown highlighted (e.g. selected) in Message 11 and 12 are EMPTY SYSTEM PANELS. Look at their Properties.  And, because they are EMPTY SYSTEM PANELS, they cannot possibly be anything other than EMPTY (e.g. zip, nada, zilch). They are only visible in the screenshots because they are selected via "Select All Instances:Visible in View".  The semi-transparent blushish color is the SELECTION color (not "glazing") that is assigned through OPTIONS.
Message 16 of 17
This is a link to a video that quickly shows you how to make one.
https://www.youtube.com/watch?v=aPXVvrnjoRU
Message 17 of 17
@Anonymous
That video you posted is NOT for creating the empty SYSTEM panel (name it Empty System Panel does not make it so), just a loadable empty curtain wall panel.  They are fundamentally different.
A loadable empty panel family as sbown in that video only works with rectanglinear shapes, where as the Empty System Panel works with any shapes.
The only way to get the Empty System Panel to a project that does not have one is via Transfer Project Standards from a project/ template as shown earlier in the thread.
We appreciate your attempt to contribute but please be carefully so that you will not be spreading false information for others, especially new users.
