show analytical view button in view conrol bar is missing
3 REPLIES 3
yadollahisheikh_1974220
254 Views, 3 Replies
Hi, I'm new to Revit and I realised the button for showing analytical view in my control bar is missing, I checked different views and templates in different projects and none of them had the button in view control bar. Is there anyway to add it?
3 REPLIES 3
Have you checked your User Interface options? Your Structure tab and tools is unchecked probably?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Problem Solved! Thank you so much Sir.
Forma Design Contest
