Hi all, I'm using Revit 2023 and I want to model infrastructure of the shopping mall.
The design includes 2 areas, a parking area and a pedestrian area (tiled). I have modeled the shapes of the design by floor, however I am not able to show these slabs sloping in two directions. Can you guide me how to model these objects?
In addition, how can the intersection position between the floor slabs match and have a smooth transition?
Thank you very much for your help
Solved by ToanDN. Go to Solution.
Solved by barthbradley. Go to Solution.
Sloping in 2 opposite directions?
-Modify Sub-Elements and bisect the Floor with a Split Line that has a higher elevation
-Join 2 Floors, that have opposing slopes, together.
- Use a Roof to represent the Floor and then you can define opposing slopes. You could even sketch the cross-sectional profile of the Floor using Roof by Extrusion.
Two easy ways:
Toan Nguyen
