sheets which affects from change objects involved
can i find sheets which affected by change any object in the model by one click ??
i means that if i change an object in the model , can i print sheets which affected by this change only instead of print all sheets ?
chrisplyler
There is no automatic way to do it, no.
You can of course SAVE a set of sheets once you have manually selected them, for easier selection in the future.
Sahay_R
After you have made changes to the model, right click on the View that you want to look at. If it is on a sheet, it will allow you the option to Open Sheet. That will allow you to  open the sheet to view and print the changes.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
chrisplyler
I think he's asking for a one-click way to print a subset of sheets...specifically ANY AND ONLY those sheets that are effected by his change. Like, if he just changes one window, he might want to print the floor plan, the elevation, and the schedules/details sheets.
Sahay_R
In that case, once the OP has opened and checked the sheets, they can print Selected Sheets. They can even save groups of sheets for repeated use. But to the best of my knowledge, Revit is not able to identify and group recently changed sheets / views.
Rina Sahay
chrisplyler
Yeah, I think that's what I said in my first post, sorta.
