Trouble with Wall Hatch
Message 1 of 8
I'm having trouble getting a wall hatch to show up in one view.  The wall has a hatch on one sheet of my plans, but on another it does not.  The detail level on both sheets is fine level, and in the graphics override the cut pattern is visible on both.  Is there somewhere else I should be looking to make this pattern visible?
Replies (7)
Message 2 of 8
dzanta
check the following:
visibility/graphics dialog box
view range
linework in plan/section/cut
view templates
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 8
Both sheets have the same view template and view range.  In the Visibility Graphics override would the wall hatch be in the model, annotation, or analytical model categories?  And how would I check the linework in the plan?
Message 4 of 8
dzanta
wall hatch would be in the Model tab
select the linework in plan and righ-click to see if there are any graphic override by elements/categories
Message 5 of 8
Man this one has really got me stumped.  The override graphics for the walls are the same between the two sheets, as well as the wall visibility settings.  It must have something to do with the sheet set my firm uses.
Message 6 of 8
dzanta
if you copy/paste the revit model data into a new revit file with default sheets...do the views look identical?
Message 7 of 8
chrisplyler
Oh, I doubt that. Unless they ONLY look different when placed ON sheets. Do they look the same when you just look at the views? Look for other clues....
Is there any Plan Region placed in one of those views?
Is the wall showing with the increased CUT line thickness in both views?
Is the scale the same for both views?
Have any Filters been applied to one of the views?
Are the view Disciplines the same?
Message 8 of 8
It turns out that it was a difference in the phasing filter.  Now the views match as they should.  Thanks for the help!
