Message 1 of 9
Sheets in Revit File not recognized by Publish Command in DOCS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a Revit File which clearly contains sheets ( I can see the 2-D sheets when I view the file within the DOCS platform). However, when I start the publish workflow within DOCS to publish to SHEETS within the BUILD platform, the workflow says that there aren't any sheets to publish. Is there a specific setting when creating sheets with Revit that must be adhered to so that the DOCS platform can recognize them? Any other suggestions as to why the workflow is not recognizing the sheets from within the Revit file?
