Why are detail lines appearing as gray in one of my design options?
1 ANTWORT 1
Nachricht 1 von 2
GMasis001
2728 Aufrufe, 1 Antwort
I have two design options. Opt A (also main model) and Opt B. Any detail line that I include in a drawing showing Opt A is shown as black but every detail line I try to incorporate on an Opt B drawing appears gray or halftone. I already checked visibility/graphics settings and the override options.
OPT A: Lines are black
OPT B: Lines are gray.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: GMasis001
Because you are still under the design option editing environment.  In that environment, only elements belong to the Design option show in full tone.  Finish editing (change the Design option in the bottom bar to Main Model) then everything will show normally.
