Sheet Table
5 REPLIES 5
1179 Views, 5 Replies
Sheet Table
I was wondering how I could make a sheet table like the one below which displays the sheet number and what is the topic of each sheet. I have made the one below using lines but it seems very Unprfessional as I want to learn how to make a direct table.
Many Thanks.
5 REPLIES 5
Alisder.Brown
Puya
You can do this by creating a "Sheet List" schedule
If you go to the "View" tab, select the drop down menu for "Schedules" you will see "Sheet List" select this
To get the output you are looking for, add SHEET NUMBER then SHEET NAME (Assuming your sheet names describe whats on the sheets) and thats you. Now you just have to place that schedule on any sheet 🙂
Hope this helps
Alisder Brown
Senior BIM Coordinator
Scotland, UK
Alfredo_Medina
On a side note, not related to your question, have you noticed on your title block, the spelling of "Architectural" ?
in reply to: Alfredo_Medina
LOL.
in reply to: Alisder.Brown
Is there a way which I can smoothly move the rows up and down? instead of having to delete them and inserting them again and then modifying their names which makes it very time consuming.
got edit properties / sorting / sort by number
Forma Design Contest
