Sheet Names on Interior Elevation Tags
4 REPLIES 4
SDG-Kelly
1270 Views, 4 Replies
Dose anyone know a way to hide the label on the interior elevation tag so it doesn't show the elevation name on the floor plan? When I add a new tag it displays the sheet name directly above the directional tag. All I want it to show is the corresponding N, S, E or W Please let me know if you have a resolution to this concern.
4 REPLIES 4
in reply to: SDG-Kelly
Look in the properties of the elevation tag. There's a check box for that
parameter.
wrote in message news:5556588@discussion.autodesk.com...
SDG-Kelly
Do you have any thoughts about what needs to be modified to hide the text? I have modified everything in the properties dialog box but was unsuccessful in hiding it. Do you have any other sugestions?
Look in Settings -> View Tags -> Elevation Tags, it's in there.
wrote in message news:5556590@discussion.autodesk.com...
SDG-Kelly
Thanks, that worked. Have a good day!
Forma Design Contest
Technology Administrators
